ANauz.1
November 10, 2020
How to install firmware patch offline
  • November 10, 2020
  • 1 reply
  • 2520 views
I have a STM32CubeMX installed on an offline cumputer (that cannot be changed!)
I would like to install the last firmware for L0 familly, so I download:
  • stm32cube_fw_l0_v1110.zip
  • stm32cube_fw_l0_v1113.zip (patch only file)
From local, there is no problem to install the version 1.11.0. But when selecting the 1.11.3 file, there is an error "corrupted or not recognized package)
How can I install the 1.11.3 FW version?
I tried to extract the 1.11.3 zip in the repository directory. But after that, the version 1.11.3 do not appear in the Packages Manager, and version 1.11.0 is no more there!
Thank you for your help
Antoine
Best answer by Khouloud ZEMMELI
Hello @ANauz.1​
Could you please Referesh the Manage Embedded SW packages ? if still there's a problem try to uncheck the use Default Firmware location then Browse and select the 1.11.3 FW version under Repository ?
Best Regards,
Khouloud
1 reply
Khouloud ZEMMELI
Khouloud ZEMMELIBest answer
Hello @ANauz.1​
Best Regards,
Khouloud
ANauz.1
ANauz.1Author
November 10, 2020
Yes it seems to work.
(Before that, I also copied the "user\.stm32cubemx\plugins\updater" directory from my online computer to the other. I do not know if it change anything)
Thank you
Khouloud ZEMMELI
Great! you are always welcome.
Best Regards,
Khouloud
