How to install CubeMX with Docker
Lyubomyr D
Hello all.
I would like to install the STM32CubeMX using Docker file for Ubuntu. How shall I do this?
I know how to use the X-server, and GUI under docker with Ubuntu, however, when downloading the STM32Cube one has to register. I would like to automate the downloading and installation process.
Please, advice me, what is the best way to do this.
Lyubomyr
5 REPLIES 5
Khouloud GARSI
Hi @Lyubomyr D​ ,
I will check if this is supported by the STM32CubeMX tool and update you ASAP.
Khouloud.
Lyubomyr D
Thank You very much!
Khouloud GARSI
You're welcome!
Khouloud.
Nawres GHARBI
Hi @Lyubomyr D​
At the end of the CubeMX install process, the installer proposes to generate an automatic script.
Please have a look on it and tell me if it does suit your needs
Lyubomyr D
Hello
I installed the Cube from command line. I did not notice ant proposals from installer. Perhaps, I have to do something special for Ubuntu 16.04 ?
