How to create a MDK-ARM Project with CUBEMX 5.6.0
- April 17, 2020
- 7 replies
- 3317 views
I have recently switched computers and i have installed Keil IDE and CubeMX 5.6.0 onto the new PC, but when i create a project i get an error saying:
"The code is successfully generated under........ but MDK-ARM V5.27 project generation have a problem"
I have tried multiple different locations to see if it was that causing the problem , but no change.
I installed CUBEMX 5.5 and 5.4 and they both show this problem however if i used V5.3 the project generates successfully.
i can obviously just work from V5.3 but this would mean i cant open any recent projects
Any help would be appreciated -i'm out of ideas what to try
