MCseh.377
HAL_PWREx_EnableVddA(); was not generated when enabling ADC1.
  • May 17, 2023
  • 1 reply
  • 1410 views
I configured ADC1 in CubeMX for a NUCLEO-U575ZI-Q board. When testing my application HAL_ADC_Enable(); returned error, RDYFLAG was not set after the timeout.
When comparing my configuration to an example I discovered that HAL_PWREx_EnableVddA(); is not called in SystemPower_Config();. The issue got resolved with enabling vdda.
I wonder if this is a code generation bug or I made some mistakes during configuration.
Best answer by Ghofrane GSOURI
Hello @MCseh.377​
First let me thank you for posting.
I assume this is the exact same issue already reported to the development team and tracked by the Ticket 102476 and that will be fixed as soon as possible.
Thx
Ghofrane
1 reply
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @MCseh.377​
Thx
Ghofrane
