Dejan Nedeljkovic
FatFs in LFN Mode: I get always FR_NOT_ENOUGH_CORE on f_open()
  • September 4, 2020
  • 4 replies
  • 1997 views
Hi
I've configured FatFs for SD 4Bit Bus and using FreeRTOS. I've set USE_LFN = 3 (dynamic working buffer on the HEAP)
When I call f_open() it always returns FR_NOT_ENOUGH_CORE.
The SD card calls are made in a seperate Task.
When USE_LFN = 0 then all works well.
Did I forget to set something?
Dejan
Tesla DeLorean
Guru
September 4, 2020
Check heap size, especially Keil.
Still failing, track malloc() usage.​
Dejan Nedeljkovic
Hi @Community member​
Heap size looks ok. I have 22 kBytes left.
Dejan
Tesla DeLorean
Guru
September 4, 2020
Probably want the breakpoint code if ff.c throwing the error, or instrument malloc/free calls.​
