Failed to use STM32CubeMX+H743+SDMMC+DMA+FATFS
- April 16, 2020
- 3 replies
- 972 views
Hello.
I am using CubeMX to generate project and code. Without using DMA I can write SD card successfully, while I enable DMA f_open will wait for 30 seconds ( timeout) and fail with an Error 1 output.
The CubeMX project is in the attachment.
I need your advice to solve this problem, thanks.
