GSeme.1
Do Changes to IOC file propagate to the code?
  • January 27, 2022
  • 946 views
I have a project and I need to change the pin assignment for peripherals. If I open the .ioc file and make the changes will those pin assignment changes propagate into the code when I re-build it?
Best answer by TDK
You need to re-generate the code in order for IOC changes to make it to source code.
GSeme.1
GSeme.1Author
Never mind.
TDKBest answer
January 27, 2022
