jeman.1
after generate code in cube.mx i am getting DTCMRAM .__USE_heapstack__overflow by 29950 ,then i fix the error it's works fine , but I am geeting error in validation target in cube.mx .. pls help me..
  • December 20, 2022
  • 1 reply
  • 749 views
1 reply
Amel NASRI
Hi @jeman.1​ ,
Could you please:
1- avoid writing the whole question in the title
2- precise the STM32 product you are using
3- provide more details on the issue: which MX version are you using? at which level exactly the error is faced? If at compilation level, which IDE are you using? how did you fixed the initial error? what do you mean by 'error in validation target'?
-Amel
To give better visibility on the answered topics, please click on "Best Answer" on the reply which solved your issue or answered your question.
