Unable to login to ST account in STM32CubeIDE
I downloaded the Version: 1.15.0 of STM32CubeIDE. It askes to login in ST for new project to download all the package. When I clicked on the myst -> login, "User Authentication Dialog" opens and nothing happens after that.
Thus I am unable to login.
Thank you in advance.
PalakBest answer
I got it fixed. My company network was blocking it. Thank you
PalakAuthor
I checked the connection.
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
PalakAuthorBest answer
Hi Palak,
I got exacly the same issue with you. Could elaborate more on the solution of your company IT team how to unblock it? Thank you.
PalakAuthor
Hi Nick,
When I used my home WIFI, I was able to login. On my company's network, software was not able to find the correct proxy, my IT fixed it and now it works on my company's network as well.
Thank you Palak! My IT followed your suggestion and also solved the issue. Indeed it is the proxy setting which prevents me to login STM32CubeIde.
Visitor II
Hi
We are having the same problem, but our IT department cannot figure out what is being blocked. Do you have a list of was done to allow your system to work ?
Hi Tajim743Z,
Please let your IT department check the proxy settings on their side. Our IT department didn't mention in detail but just let me know they enabled the proxy port for STM32CubeIDE to access.
JKapp.1
What url and ports need to be unblocked?
