Jan 25, 2024 2:06 PM UTC
STM32cubeIDE SWV trace autostop
I am new on STM32CubeIDE. I try to use SWV to trace some parameters from Nucleo-H743ZI2. At the beginning, everything is ok. I can see the data in the trace window. But the trace will automatically stop after a certain duration. The board is still running, as I can see the LED still blinking. I am thinking if there is any limitation on the trace duration or data size?
Can anyone give me some guide where I should check? Thank you.
    LaurentL
    LaurentLBest answer
    Jan 26, 2024 1:33 PM UTC
    There was a regression in STLink fw V3J13 for SWV.
    So, check your Fw version and update to V3J14.
    Rgds,
    Laurent
    STTwo-32
    Jan 25, 2024 3:03 PM UTC
    Hello @Jiaming
    I suggest you increase the Trace buffer size under Window >Preferences >STM32Cube >Serial Wire Viewer.
    Best Regards.
    STTWo-32
    JiamingAuthor
    Jan 26, 2024 1:56 AM UTC
    Hello @STTwo-32,
    I increased the buffer size in the Serial Wire Viewer, from 2,000,000 to 20,000,000, but the trace still stopped at the exact same time as before, at 73.5s
    It seems something limited the trace to continue...Is it because the target does not have enough memory? After the SWV trace stopped, i can see the value in the upper right "Live Expressions" is still updating.
    BR,
    JN
    LaurentL
    LaurentLBest answer
    Rgds,
    Laurent
