STM32CubeIDE doesn't save clock configuration
  • September 11, 2024
  • 6 replies
  • 1395 views
Hi, I'm facing a problem with the Clock Configuration tab with the latest version of the STM32CubeIDE. In fact, every time I open the ioc file, there is an error with the SMPS Clock Mux on the STM32WB board I'm using. I correct and generate code and saved but when I open the file again the error is still there. I'm using the latest version of the Cube.
Thanks.
    Best answer by mƎALLEm
    @mƎALLEm wrote:
    I reproduced the behavior.
    I will escalate the issue internally and get back to you as soon as I have an answer/feedback.
    Internal ticket 190817 for follow-up.
    Issue fixed in CubeMx V6.13.0
    mƎALLEm
    What error is displayed? Could you please share your ioc file?
    I share some pictures of the problem. To correct the problem, I change the SMPS Clock Mux to HSE as shown in the tutorial. However, when I generate the code and save it goes to HSI again. I attach also the ioc.
    Thanks.
    mƎALLEm
    Thank you for your patience.
    mƎALLEm
    mƎALLEmBest answer
    I have the same issue with CubeMX V6.15.0
    Is there some way how to fix it? Thanks.
