2025-03-14 10:01 AM
I am facing an issue while installing the cube ide in my rhel 9.2 version,the exact problem was when i try to run the executable file and going through the instructions ,after agreeing the licenses and the folder which contains .rpm files is deleting automatically and causing an error like no matches found for .rpm something like that.
2025-03-19 12:50 AM
Hello @shyammulla ,
First let me thank you for posting.
Supported operating systems and architectures for STM32CubeIDE:
• Windows® 10 and 11, 64 bits (x64)
• Linux®: Ubuntu® LTS 22.04 and LTS 24.04, and Fedora® 41
• macOS® 14 (Sonoma), macOS® 15 (Sequoia)
Thanks.
Mahmoud
2025-03-19 12:50 AM
Hello @shyammulla ,
Thanks.
Mahmoud
