RAMT component integration issues
bharadwaj
I am facing issues while integrating RAMT(ram test) component. As per our doc,they are suggesting to add some compiler options
COMPILER_OPTIONS_ramt_algo += --diag_suppress=Pe1053 to mute some errors.Already I have added this in the Miscellaneous filed under the MCU GCC Assembler and MCU GCC Compiler. But still problem is there. It is showing like this.Is there anyway of overcoming this..How to add and how I can come out form this..?
Kindly help out me here!!
Best regards,
Roger SHIVELY
Hello @bharadwaj ,
Thank you for contacting STMicroelectronics.
Your post was escalated to ST Online Support Team for additional assistance.
Kind Regards,
Roger
ST Support
