AScha.3
in Cube for H563 no FatFS available - why ? Bug ? forget ?
  • September 23, 2023
  • 4 replies
  • 2992 views
in IDE 1.13.1 -> cubemx : no fatfs !  why ?? force to use MS excrement filex ?
    Best answer by AScha.3
    Oo , never had the idea, STM still having 6 year old version as "standard" . perfect, fine.
    so i put in actual version of fatfs , together with Azure core . :)  seem working good now.        mount, readdir ok.
    Thx for your info .
    Tesla DeLorean
    Guru
    September 23, 2023
    Other versions using very stale build with known issues.
    I might guess licensing or pressure from MS and support of EXFAT.
    I'd prefer to see FATFS as an available alternative.
    AScha.3
    AScha.3Author
    right. now your forced to Azure rtos, because filex only working with enabled Azure.
    and "old" fatfs working fine with exfat (has : enable : exfat in settings).
    i tried azure+filex now some hours over the last 4 days, just as i feared: cannot mount old 64GB sdcard, i always use for my first tests. and a new 2GB (fat32) card after some 30..40 starts now also no more mount.
    and i never write anything !!! only mount and read directory (first entry..called). so very suspicious .
    i dont want use filex anymore.
    i want fatfs from Mr. Chan again. this never made such curious problems.
    Tesla DeLorean
    Guru
    September 23, 2023
    I've used newer versions of FATFS on larger volumes (think 200-400 GB), the 2017 versions ST shipped have integrity issues in stress tests, but these were fixed on more recent versions, however ST never bothered to migrate to these. I used my own builds/ports.
