IMU sensors with DatalogTerminal not working properly
- July 3, 2024
- 8 replies
- 2210 views
Hi, im using the nucleo F401RE with the X-NUCLEO IKS01A3 and the Steval MKI197v1, i used CubeMX to insert the x-mems1 library, the aplication DataLogTerminal and only selected the LSM6DSOX sensor (steval).
I set the LSM6DSOX's SA0 pin to GND to prevent address conflicts, the I2C to Fast Speed Mode and ran the code generated on STM32CubeIDE.
When first launched it worked nice, but as i unplug the board and plug it back again it wont work anymore. Not even after compiling it again.
The only way i found to make it work again is to upload a different code on the nucleo and after that, upload the troublesome code.
Any advice on this? I attack the .ioc below.
Thanks in advance.
