Ruslan1
How to uninstall it?
  • May 31, 2019
  • 3 replies
  • 4320 views
I've tried to uninstal it from Windows7 standard "programs and components". It's said that the "Program has already been uninstalled, remove from the list". But nothing actually has changed. Now I can't reinstall the IDE cause the installer argues that it is already installed.
What a ....!
Best answer by Ethan HUANG
​We've seen such issue over some systems running anti-virus which may prevent uninstall.exe from installing. Here is a workaround:
  1. Delete CubeIDE installation folder manually (default: C:\ST\STM32CubeIDE_1.0.0)
  2. Run "regedit" to delete this key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\STMicroelectronics\STM32CubeIDE\1.0.0
Ethan HUANG
Ethan HUANGBest answer
Ruslan1
Ruslan1Author
Thanks! It helped.
Giangiacomo Zaffini
Ok. Is there a specific uninstall policy and/or tool for the case of GNU/Linux o.s. such Ubuntu?
