How to see only a part of an array in expression view?
MFran.4
Hello!
My case is:
I have an array of 100 items, but now I know only the first 10 are used so I'd like to watch only the first ten variables.
I know I can list the individual array items one after another (e.g, arr[0], arr[1] and so on to arr[9]), but I was wondering if there's a better way to do it.
I imagined something like
arr[0-10]
arr[:10]
arr[0], 10
arr, 10
Thanks!
Right click the array in the "Variable" tab -> Display as array -> choose new bounds.
If you wanted to show items 90-100, you could dereference the 90th item to get a pointer and do the same thing.
4 REPLIES 4
Thank you so much! Exactly what I hoped.
Do you know if this is possible also in the "Live Expressions" view as it is in expressions and variables? From what I see, it can't be done.
Try it. If it works, it works. If it doesn't, it doesn't.
Excellent piece of advice.
Thanks again!
