Fault analyzer toolbar missing
  • December 20, 2023
  • 5 replies
  • 2546 views
Hello everybody,
Since I did last update of STM32CubeIDE software I cannot see the fault analyzer toolbar anymore (attached file img).
Am I missing some configuration to display it?
Or is due to the update?
Thank you for your time
    Hello @lucius92 ,
    First let me thank you for posting and welcome to ST Community.
    I suggest that you Select the menu command [Window]>[Show View]>[Others] and tap [Fault Analyzer] or use the [Quick Access] field and search for “Fault Analyzer” and select it from the views.
    Thanks.
    Mahmoud.
    Hi Mahmoud,
    I am seeing the same issue using the latest version.
    Dan
    The issue is reported internally to our team (Internal ticket number : 174586) and it will be fixed as soon as possible.
    Thanks.
    Mahmoud.
    lucius92Author
    Hello @Mahmoud Ben Romdhane
    I correctly display Fault analyzer but there is no toolbar  (also when there is a fault)
    Did this issue get fixed?
    I don't see the Fault Analyzer toolbar in the Fault Analyzer Window or am I just looking in the wrong place for it?
    I'm using STM32CubeIDE V1.15.1 (Build 21094_20240412_1041)
