2021-06-16 8:56 AM
Hi!
I'm developing a project bassed on the SUB_GHZ_PINGPONG example from ST. First, Every time I change something on cubeMX it creates files on the wrong directories and i have to delete them manually. This is an common problem that is well documented.
The second problem, and the reason of this question is that every time I try to export the modified project and import it again, it's empty. I've open the files on the explorer and those are empty too.
How can i export this example as if it were a normal project?
Thank you very much for your time!
2021-06-16 1:10 PM
How are you exporting ? ... I'm afraid no STM32Cube vaulable support looking for export ...
