DYann.1
Senior II
November 20, 2024
Error : make: *** No rule to make target.....
Someone sends me a project but when I open it on my PC I encounter the following error :
make: *** No rule to make target 'C:/Users/ghithab/STM32Cube/Repository/STM32Cube_FW_L5_V1.5.1/Middlewares/Third_Party/FatFs/src/option/ccsbcs.c', needed by 'Middlewares/FatFs/ccsbcs.o'. Stop. FatFs_uSD_Standalone C/C++ Problem
Do you know how to fix this problem ? However in my directory I have the file in question :
This probably comes from the configuration path but I only see points....
How i can see the full path instead of the....
Thank you for your helps
mƎALLEm
Was this file added to the project:
-> This is an example from https://github.com/STMicroelectronics/STM32CubeL5/tree/master/Projects/STM32L562E-DK/Applications/FatFs/FatFs_uSD_Standalone
Otherwise, if possible to share with us your project. If not possible to share it in public send it to me in private.
DYann.1
DYann.1Author
Senior II
November 20, 2024
Thank you for your answer, Can I send you privately ? Please
mƎALLEm
Yes
