MBora.2
Cube IDE give error "Unhandled event loop exception Java heap space"
Hello everyone.
After installing Cube IDE and trying to create new project take this error.
Also i tried to solve the problem according this guide but without success (translate to English):
http://430895101.blogspot.com/2014/02/eclipse-unhandled-event-loop-exception.html
Logs of error0693W000008vzwbQAA.png:
java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Arrays.java:3332)
at java.lang.AbstractStringBuilder.ensureCapacityInternal(AbstractStringBuilder.java:124)
at java.lang.AbstractStringBuilder.append(AbstractStringBuilder.java:596)
at java.lang.StringBuilder.append(StringBuilder.java:190)
at java.io.BufferedReader.readLine(BufferedReader.java:370)
at java.io.BufferedReader.readLine(BufferedReader.java:389)
at com.st.microxplorer.plugins.updater.util.ParameterSetting.reload(ParameterSetting.java:110)
at com.st.microxplorer.plugins.updater.util.ParameterSetting.load(ParameterSetting.java:84)
at com.st.microxplorer.plugins.updater.engine.MainUpdater.openIniFile(MainUpdater.java:3108)
at com.st.microxplorer.plugins.updater.engine.MainUpdater.<init>(MainUpdater.java:205)
at com.st.microxplorer.plugins.updater.Updater.initPhase2(Updater.java:1030)
at com.st.microxplorer.plugins.updater.Updater.setUserPreferencesHandler(Updater.java:1083)
at com.st.stm32cube.common.mx.core.CubeMxInstance.<init>(CubeMxInstance.java:125)
at com.st.stm32cube.common.mx.core.CubeMxInstance.getInstance(CubeMxInstance.java:70)
at com.st.stm32cube.common.mx.targetselector.TargetSelectorAdapter.addTargetSelector(TargetSelectorAdapter.java:132)
at com.st.stm32cube.common.projectcreation.ui.wizard.TargetSetupPageAbstract.createControl(TargetSetupPageAbstract.java:126)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:178)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:743)
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:635)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1094)
at org.eclipse.jface.window.Window.open(Window.java:788)
at com.st.stm32cube.ide.mcu.informationcenter.WelcomePageAction.run(WelcomePageAction.java:54)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL.runAction(IntroURL.java:280)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL.doExecute(IntroURL.java:191)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL.lambda$0(IntroURL.java:146)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL$$Lambda$582/499302716.run(Unknown Source)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:72)
at org.eclipse.ui.internal.intro.impl.model.url.IntroURL.execute(IntroURL.java:146)
at org.eclipse.ui.internal.intro.impl.presentations.BrowserIntroPartLocationListener.changing(BrowserIntroPartLocationListener.java:130)
at org.eclipse.swt.browser.IE.lambda$6(IE.java:525)
at org.eclipse.swt.browser.IE$$Lambda$427/1067780644.handleEvent(Unknown Source)0693W000008vzw7QAA.pngCube version: 1.6.1, 1.5.1 (both versions give error)
Parameters of PC:
Windows 10,v 10.0.19041
Video Card :Intel(R) UHD Graphics 620
CPU:  i3-8145U CPU @ 2.10GHz
RAM: 8Gb
Please advice.
Cartu38 OpenDev
Graduate II
March 4, 2021
Maybe exit IDE session, move all <user home>/.stm32* to some backup area then restart IDE back.
Let us know if helping.
MBora.2
MBora.2Author
CUbe:
C:\ST\STM32CubeIDE_1.5.1\STM32CubeIDE
Workspace:
C:\ST\workspace
workspace folder is empty. Do you mean move Cube ID folder?
Cartu38 OpenDev
Graduate II
March 5, 2021
None of them.
You have some STM32Cube extra metadata under your user home folder. all are prefixed '.stm'
If windows most of time 'c:\Users\<user name>\.stm*'
MBora.2
MBora.2Author
It is done. Sucess!
  1. I found few folders with ".stm" prefix in  'c:\Users\<user name>\
  2. and removed them0693W000008wLn7QAE.png. (summary about 500+mb)
And issue has gone!
You was write. Thank you!
Cartu38 OpenDev
Graduate II
March 9, 2021
Please tag such topic as answered. Will help community to dig more efficiently into valuable material. Thanks.
MBora.2
MBora.2Author
Sorry, i don't see correspoding settings. And i can't create topics with new name. What i have to do?
