DMcCu.2
Visitor II
November 6, 2020
Debugging issue: "arm-none-eabi-gdb.exe has stopped working"
  • November 6, 2020
  • 3 replies
  • 5597 views
When I try to debug my code before running, I get the following error "arm-none-eabi-gdb.exe has stopped working". I am using STM32CubeIDE 1.4.0 with a Nucleo L476RG board. I have tried restarting the IDE and computer. Any advice is appreciated, thanks.
MPanz.1
Visitor II
November 30, 2020
Experiencing the same issue. Any help with getting past this error?
LaurentL
Can you try on the new STM32CubeIde 1.5.0 ?
Thanks,
Laurent
MPanz.1
Visitor II
November 30, 2020
I am using 1.5.0. Just bought a Nucleo64 board to play around with the STM32 and following Digikey's youtube intro videos. But I did fix the issue last night by playing around with the Debug Configuration settings. I set the Reset Behavior to "Software System reset" and the issue went away. Thanks for replying.
Markus GIRDLAND
If you go into debug configuration and activate the "gdb server log" and set the settings to when it crashed. Could you send that log to me?
You can send it to me in a private message.
JWait.1
Visitor II
March 28, 2021
I tried to modify debug configuration as Markus mentioned above, then this issue doesn't appear on my L476RG.
I am using IDECube 1.6.0 / Windows 10 OS.
