Cube pack sync error via vscode proxy
Hello! I installed the extension and configured it to work through a proxy (downloading the compiler, etc.), and everything works fine, but when I try to download devices list via cube pack sync, I get the error:
Failed to download with Unsupported `GLOBAL_AGENT.HTTP_PROXY` configuration value: URL protocol must be "http:"
I tried adding the proxy via platform environment variables, but that didn't help.
Platform: Win11
IDE pluggin: 3.6.4
Pack manager: 0.3.12
Julien D
Julien DBest answer
This issue has been analyzed and understood, having a fix will require a significant effort.
Be assured that we are not telling we won't have it, however, short term, we can only suggest you to use proxies based on http protocol, not https, apologies for the inconvenience.
T1FWK-4047
Julien D
@Wyrm, I confirm I can repro the issue using an https proxy. An internal ticket will be created.
In the meantime are you able to try with an http proxy instead ?
T1FWK-4047
Julien D
Julien DBest answer
T1FWK-4047
WyrmAuthor
Thanks! I changed it to http and it worked for me.
Visitor
Thanks for the detailed update. I appreciate the transparency about the effort required for a proper fix. Using HTTP proxies as a temporary workaround is helpful, although I hope HTTPS support can be added in a future release. I ran into a similar discussion while troubleshooting proxy access for Pirate Bay, so this explanation helped me better understand the limitation. Thanks for keeping the community informed.
