Aziz BRIGUI
StickyQuestion
STM32CubeProgrammer v2.22 released
  • February 24, 2026
  • 0 replies
  • 316 views
We are pleased to announce that STM32CubeProgrammer 2.22 is available
What is new in 2.22:
Support for the STM32U3 microcontrollers with 2 Mbytes of flash memory:
  • Internal memory programming through debug and bootloader interfaces
  • Option bytes programming through debug and bootloader interfaces
  • OTP programming through debug and bootloader interfaces
  • Core register programming through debug interfaces
  • Automatic mode
  • Serial Wire Viewer
  • Register viewer
  • Firmware encryption/signing
  • RDP regression with password
  • SFI through debug and bootloader interfaces (USB and UART)
Support for STM32C5 series microcontrollers:
  • Automatic mode
  • Register viewer
Support for STM32WBA2xxx microcontrollers:
  • External memory programming through debug interfaces
  • Automatic mode
  • Register viewer
Support for the STM32H5 microcontrollers with 4 Mbytes of flash memory:
  • Automatic mode
  • Register viewer
  • OBkey generation/provisioning
  • Certificate generation
  • Debug authentication
  • License generation
  • Secure Manager install
Debug authentication on Windows® 32 bits
Export of MCU memory map:
  • Simplified the memory map dump (option bytes, OTP, internal/external flash memory) in HEX output file format
Support for OBKey generation and signing with SHA‑384 and ECDSA‑P384 in STM32 Trusted Package Creator:
  • Added the support for SHA-384 and ECDSA-P384 encryption types
Main fixed issues in 2.22:
Refer to the STM32CubeProgrammer wiki at:
STM32CubeProgrammer errata 2.22.x - stm32mcu
Known problems and limitations in 2.22:
How to get STM32CubeProgrammer 2.22:
  • Under this link
  • Or update your current installation of STM32CubeProgrammer using: Help > Software update
