Dec 5, 2023 12:06 UTC
USB PHY issue in STM32mp157A
I am working on a custom board based on STM32MP157A and I am getting all the bits correctly but getting values at reserved bits in USBPHYC version register (Internal) which are supposed to be reserved  as per the reference manual.
Below mentioned screenshots contains :
1.Register from reference manual:
2.Below attached image contains values I am getting when reading the register:
And I am confused on how to move forward with usbphy.I hope someone could help me with the problem
Thanks&Regards
Srikanth
PatrickF
PatrickFBest answer
Dec 5, 2023 12:21 UTC
HI @Srikanth1
you are right, there is a mistake in the offset of this register in the reference manual. Correct offset is 0x3F4
Thanks to pointing this issue, will be corrected in a future revision of the document.
Regards,
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
PatrickFBest answer
HI @Srikanth1
Regards,
Srikanth1Author
Dec 6, 2023 04:46 UTC
Hi @PatrickF
            Thanks for the reply,now we could read the register correctly.And as of now I am stuck on how to move forward and what can be the next step to be done.
I hope You could help me with forward with the usb.
Thanks &Regards,
srikanth.
PatrickF
Dec 6, 2023 09:46 UTC
This missing register should be present in a future revision of the STM32MP15 reference manual.
Meanwhile, you could find it in the STM32MP13 reference manual (RM0475) which uses same USBPHYC.
There is some missing IP identification registers which are missing, but read-only and not used by the driver. For the sake of completeness, those will be added too.
Btw, I will correct my first answer as USBPHYC_VERR register offset if 0x3F4 (0xFF4 is true, but is a mirroring view). Will be corrected as well in RM0475.
