Please tell me about what "st-image-xxxxx" parameter means.
  • December 11, 2020
  • 4745 views
I want to know what "st-image-xxxxx" parameter mean.
Especially, I want to know what name of xxxxx (for example "weston") means.
Is the name of xxxxx related to the name of some config file?
For example, if I changed the name of xxxxx to any name from weston, Are output files by bitabake influenced?
​Best Regards,
H. Masuda.
Best answer by KnarfB
Its the name of the recipe file in layers/meta-st-openstlinux/recipes-st/images/. So you might look up the recipe and see what else is possible or change the recipe according to your needs (Best done in your own layer).
KnarfB
KnarfBBest answer
HMasu.1Author
Hi @KnarfB​
Thank you for your reply.
I understood very well.
So, when we create our own machine, Should we create our own layer(meta-***), and create recipe file in our own layer instead of using "weston"?
H. Masuda
