KNono
Jul 12, 2021 13:21 UTC
Fail the Image flashing on STM32MPU157F-DK2
I am trying to flash the Starter_Package to SD card in accordance with the following wiki("6.2 Image flashing"). But fail.
https://wiki.st.com/stm32mpu/wiki/STM32MP15_Discovery_kits_-_Starter_Package#Image_flashing
Unfortunately i am a complete beginner on these tools and don't understand what is happened.
Thank you by advance for any help or advices.
error log are...
Error: failed to download Segment[0]
Error: failed to download the File
Error: Download partition 0x06 failed
Error: TSV flashing service failed
My environments are below,
Bord:STM32MPU157F-DK2.
Host PC: Windows10 64 bit
SD card: ADATA 16GB
[Full log]
            STM32CubeProgrammer v2.7.0
USB speed  : High Speed (480MBit/s)
Manuf. ID  : STMicroelectronics
Product ID : DFU in HS Mode @Device ID /0x500, @Revision ID /0x0000
SN     : 002700363030510D32313933
FW version : 0x0110
Device ID  : 0x0500
Device name : STM32MP1
Device type : MPU
Device CPU : Cortex-A7
Start Embedded Flashing service
Memory Programming ...
Opening and parsing file: tf-a-stm32mp157f-dk2-usb.stm32
 File     : tf-a-stm32mp157f-dk2-usb.stm32
 Partition ID : 0x01
Download in Progress:
ロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロ 100%
File download complete
Time elapsed during download operation: 00:00:00.479
RUNNING Program ...
 PartID:   :0x01
Start operation done successfully at partition 0x01
Flashlayout Programming ...
Running Flashlayout Partition ...
Flashlayout partition started successfully
Opening and parsing file: fip-stm32mp157f-dk2-trusted.bin
 File     : fip-stm32mp157f-dk2-trusted.bin
 Partition ID : 0x03
Time elapsed during download operation: 00:00:01.548
RUNNING Program ...
 PartID:   :0x03
Reconnecting the device ...
Product ID : USB download gadget@Device ID /0x500, @Revision ID /0x2001, @Name /STM32MP157FAC Rev.Z,
FW version : 0x0110
Device ID  : 0x0500
Start operation done successfully at partition 0x03
Opening and parsing file: tf-a-stm32mp157f-dk2-sdcard.stm32
 File     : tf-a-stm32mp157f-dk2-sdcard.stm32
 Partition ID : 0x04
Time elapsed during download operation: 00:00:00.062
RUNNING Program ...
 PartID:   :0x04
Start operation done successfully at partition 0x04
 Partition ID : 0x05
Time elapsed during download operation: 00:00:00.066
RUNNING Program ...
 PartID:   :0x05
Start operation done successfully at partition 0x05
 Partition ID : 0x06
ロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロロアアア 94%
PatrickF
PatrickFBest answer
Jul 12, 2021 13:57 UTC
did you try using another computer, another board supply, another USB cable ?
Otherwise, could you try if using the attached Flashlayout file file would help ?
FlashLayout_sdcard_stm32mp157f-dk2-trusted(trial).tsv file should be extracted from attached .zip and copied in flashlayout_st-image-weston/trusted/ folder, and then use the following command:
STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/trusted/FlashLayout_sdcard_stm32mp157f-dk2-trusted(trial).tsv
Regards.
In order to give better visibility on the answered topics, please click on 'Best Answer' on the reply which solved your issue or answered your question.Tip of the day: Try Sidekick STM32 AI agent
PatrickF
PatrickFBest answer
Regards.
rbarris
Mar 4, 2023 20:55 UTC
@PatrickF​ Hi Patrick, I just experienced the same type of problem using the same board: STM32MP157F-DK2.
Have its USB-C power connected to a dedicated USB-C brick (Apple laptop charger). USB-C OTG port plugged into Linux host PC by single cable to a USB3 port.
Errors looked like this - would get partway through this partition each time, failing at a random percentage..
RUNNING Program ...
 PartID: :0x08
Start operation done successfully at partition 0x08
Opening and parsing file: st-image-bootfs-openstlinux-weston-stm32mp1.ext4
 File : st-image-bootfs-openstlinux-weston-stm32mp1.ext4
 Partition ID : 0x10
[====== ] 12%
Error: Download partition 0x10 failed
I grabbed your trial TSV and was able to flash successfully through DFU. IMO that rules out cables, power, host PC etc etc. (well it completed flashing, but it cannot actually boot... see below)
But this is March 2023 and I'm using the 4.1.0 starter package from ST website.. so I have some doubts as to whether using the hacked TSV from a couple years ago is best practice.. instead can we articulate what modifications if any, should be applied to the flashlayout_st-image-weston/trusted/FlashLayout_sdcard_stm32mp157f-dk2-trusted.tsv which is included in today's Starter Package ?
en.FLASH-stm32mp1-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23/stm32mp1-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23/images
DL from here
https://www.st.com/en/embedded-software/stm32mp1starter.html
starter package process here
device listing:
~/stmp2/en.FLASH-stm32mp1-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23/stm32mp1-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23/images$ STM32_Programmer_CLI -l usb
 STM32CubeProgrammer v2.13.0
===== DFU Interface =====
Total number of available STM32 device in DFU mode: 1
 Device Index : USB1
 USB Bus Number : 001
 USB Address Number : 003
 Serial number : 003200193438511836383238
 Firmware version : 0x0110
 Device ID : 0x0500
today's TSV from en.FLASH-stm32mp1-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23
more flashlayout_st-image-weston/trusted/FlashLayout_sdcard_stm32mp157f-dk2-trusted.tsv
#Opt	Id	Name	Type	IP	Offset	Binary
-	0x01	fsbl-boot	Binary	none	0x0	arm-trusted-firmware/tf-a-stm32mp157f-dk2-usb.stm32
-	0x03	fip-boot	FIP	none	0x0	fip/fip-stm32mp157f-dk2-trusted.bin
P	0x04	fsbl1	Binary	mmc0	0x00004400	arm-trusted-firmware/tf-a-stm32mp157f-dk2-sdcard.stm32
P	0x05	fsbl2	Binary	mmc0	0x00044400	arm-trusted-firmware/tf-a-stm32mp157f-dk2-sdcard.stm32
P	0x06	metadata1	Binary	mmc0	0x00084400	arm-trusted-firmware/metadata.bin
P	0x07	metadata2	Binary	mmc0	0x000C4400	arm-trusted-firmware/metadata.bin
P	0x08	fip-a	FIP	mmc0	0x00104400	fip/fip-stm32mp157f-dk2-trusted.bin
PED	0x09	fip-b	FIP	mmc0	0x00504400	none
PED	0x0A	u-boot-env	Binary	mmc0	0x00904400	none
P	0x10	bootfs	System	mmc0	0x00984400	st-image-bootfs-openstlinux-weston-stm32mp1.ext4
P	0x11	vendorfs	FileSystem	mmc0	0x04984400	st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
P	0x12	rootfs	FileSystem	mmc0	0x05984400	st-image-weston-openstlinux-weston-stm32mp1.ext4
P	0x13	userfs	FileSystem	mmc0	0x105984400	st-image-userfs-openstlinux-weston-stm32mp1.ext4
 Results of trying to boot using a DFU-flashed card using the "trial" TSV.. it's unhappy about missing partitions. Which leads me back to wanting to figure out what modification is needed to the modern TSV that came in the starter package..
NOTICE: CPU: STM32MP157FAC Rev.Z
NOTICE: Model: STMicroelectronics STM32MP157F-DK2 Discovery Board
NOTICE: Board: MB1272 Var4.0 Rev.C-02
INFO: PMIC version = 0x20
INFO: Reset reason (0x15):
INFO: Power-on Reset (rst_por)
INFO: FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000
INFO: FCONF: Reading firmware configuration information for: stm32mp_io
INFO: Using SDMMC
INFO: Instance 1
INFO: Boot used partition fsbl1
NOTICE: BL2: v2.6-stm32mp1-r2.0(debug):v2.6-dirty(a1f02f4f)
NOTICE: BL2: Built : 13:14:26, Nov 23 2021
ERROR: Unable to find a metadata partition
WARNING: Failed to set reference to image id=12 (-2)
WARNING: loading of FWU-Metadata failed, using Bkup-FWU-Metadata
WARNING: Failed to set reference to image id=13 (-2)
ERROR: loading of Bkup-FWU-Metadata failed
rbarris
Mar 4, 2023 23:13 UTC
I eventually did succeed in DFU flashing with the unmodified TSV file from the current day starter package for 4.1.0 (and it does boot properly). But it was very flaky, took half a dozen tries. I hope I don't have to do that very often.
KNono
KNonoAuthor
Jul 13, 2021 12:21 UTC
Dear PatrickF,
Thank you for your quick response.
It was success with your new file.
Start operation done successfully at partition 0x13
Flashing service completed successfully
I can move to next step.
Thank you!
[full log]
C:\Users\nonoguchi\clickplus_nodered\Starter-Package\stm32mp1-openstlinux-5.10-dunfell-mp1-21-03-31\images\stm32mp1>STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/trusted/FlashLayout_sdcard_stm32mp157f-dk2-trusted(trial).tsv
FW version : 0x0110
Device ID  : 0x0500
Device type : MPU
Opening and parsing file: tf-a-stm32mp157c-dk2-usb.stm32
 File     : tf-a-stm32mp157c-dk2-usb.stm32
 Partition ID : 0x01
Time elapsed during download operation: 00:00:00.464
RUNNING Program ...
 PartID:   :0x01
Opening and parsing file: fip-stm32mp157c-dk2-trusted.bin
 File     : fip-stm32mp157c-dk2-trusted.bin
 Partition ID : 0x03
Time elapsed during download operation: 00:00:01.445
RUNNING Program ...
 PartID:   :0x03
FW version : 0x0110
Device ID  : 0x0500
 Partition ID : 0x04
Time elapsed during download operation: 00:00:00.076
RUNNING Program ...
 PartID:   :0x04
 Partition ID : 0x05
Time elapsed during download operation: 00:00:00.078
RUNNING Program ...
 PartID:   :0x05
 Partition ID : 0x06
Time elapsed during download operation: 00:00:00.454
RUNNING Program ...
 PartID:   :0x06
Start operation done successfully at partition 0x06
 Partition ID : 0x10
Time elapsed during download operation: 00:00:25.330
RUNNING Program ...
 PartID:   :0x10
Start operation done successfully at partition 0x10
Opening and parsing file: st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
 File     : st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
 Partition ID : 0x11
Time elapsed during download operation: 00:00:07.381
RUNNING Program ...
 PartID:   :0x11
Start operation done successfully at partition 0x11
Opening and parsing file: st-image-weston-openstlinux-weston-stm32mp1.ext4
 File     : st-image-weston-openstlinux-weston-stm32mp1.ext4
 Partition ID : 0x12
Time elapsed during download operation: 00:04:23.865
RUNNING Program ...
 PartID:   :0x12
Start operation done successfully at partition 0x12
Opening and parsing file: st-image-userfs-openstlinux-weston-stm32mp1.ext4
 File     : st-image-userfs-openstlinux-weston-stm32mp1.ext4
 Partition ID : 0x13
Time elapsed during download operation: 00:01:00.156
RUNNING Program ...
 PartID:   :0x13
