Android repo init error ?
‎2019-10-17 3:51 AM
I try to compile Android on the STM32MP1 following the Wiki and I'm hitting a problem :
hico@debian-ha:~/work/st/android$
hico@debian-ha:~/work/st/android$ repo init -u https://github.com/STMicroelectronics/android-manifest -b st-android-9.0.0-2019-09-27 -m stm32mp1droid.xml
Get https://gerrit.googlesource.com/git-repo/clone.bundle
remote: Counting objects: 1, done
remote: Finding sources: 100% (64/64)
remote: Total 64 (delta 6), reused 64 (delta 6)
Unpacking objects: 100% (64/64), done.
From https://gerrit.googlesource.com/git-repo
fb527e3..d1e93dd master -> origin/master
a2cd6ae..e778e57 stable -> origin/stable
* [new tag] v1.13.7 -> v1.13.7
... A new repo command ( 1.26) is available.
... You should upgrade soon:
cp /home/hico/work/st/android/.repo/repo/repo /home/hico/bin/repo
Get https://github.com/STMicroelectronics/android-manifest
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (22) The requested URL returned error: 404 Not Found
Server does not provide clone.bundle; ignoring.
fatal: Couldn't find remote ref refs/heads/st-android-9.0.0-2019-09-27
Any idea what's wrong with this ?
Anthony Harivel
- Labels:
STM32MP15 Lines
‎2019-10-17 4:25 AM
Hi @anthony.harivel.emtrion.GmbH​
Correct command syntax is :
repo init -u https://github.com/STMicroelectronics/android-manifest -b refs/tags/st-android-9.0.0-2019-09-27 -m stm32mp1droid.xml
We will update wiki to specify it.
Olivier
‎2019-10-17 4:25 AM
Olivier
