Visitor II
March 8, 2024
Porting custom yocto distro from STM32MP151A to STM32MP151C
  • March 8, 2024
  • 1 reply
  • 1467 views
we are currently porting a custom dunfell distro from STM32MP151A to STM32MP151C.
We followed the guides related to creating our own machine by generating the device tree in CubeMX and succeeded in building it correctly.
https://wiki.st.com/stm32mpu/index.php/How_to_create_your_own_machine
Attempting to flash the board crashes in writing the first partition related to the file "arm-trusted-firmware/tf-a-stm32mp151c-my-project-mx-usb.stm32". What could be the cause?
Attached my conf/machine/<machine>.conf file (extended extension to .txt for uploading)
I would like to thank you for any help.
Best answer by Olivier GALLIEN
Hi @sghezz ,
dunfell distro means you are in Version 3.1 or earlier .. which is no longer supported by ST.
If you are starting a new developpement I really advise to switch on latest DV5.0.
If you would like to stick on such old version be aware that you might refer to the corresponding Wiki https://wiki.st.com/stm32mpu-ecosystem-v3/wiki
Content of the latest wiki is not guarantee for usage on old version.
Be careful also to use the right CubeMX version ( refer to wiki V3 ) . Using latest one only generate Device tree for DV5.0 OSTL.
Hope it help
Olivier
1 reply
Olivier GALLIEN
Olivier GALLIENBest answer
Hi @sghezz ,
Hope it help
Olivier
