Joel
Aug 25, 2022 15:07 UTC
STM32MP157F-DK2 failing to boot on custom image
I'm targeting:
openstlinux-5.15-yocto-kirkstone-mp1-v22.07.27
DISTRO: openstlinux-eglfs
MACHINE: stm32mp15-disco
Image+SDK build fine. I create the raw file as usual, image SD card, and boot fails with:
NOTICE: Model: STMicroelectronics STM32MP157F-DK2 Discovery Board
NOTICE: Board: MB1272 Var4.0 Rev.C-02
INFO:   PMIC version = 0x20
INFO:   Reset reason (0x15):
INFO:     Power-on Reset (rst_por)
INFO:   FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000
INFO:   FCONF: Reading firmware configuration information for: stm32mp_io
INFO:   Using SDMMC
INFO:     Instance 1
INFO:   Boot used partition fsbl1
NOTICE: BL2: v2.6-stm32mp1-r1.0(debug):v2.6-dirty
NOTICE: BL2: Built : 13:14:26, Nov 23 2021
WARNING: CRC check failed on FWU metadata
WARNING: loading of FWU-Metadata failed, using Bkup-FWU-Metadata
ERROR:  loading of Bkup-FWU-Metadata failed
PANIC at PC : 0x2ffea213
I have no troubles using dunfell release with machine `stm32mp1-disco`.
My kirkstone CI (fails to boot):
https://github.com/meta-flutter/meta-flutter/blob/kirkstone/.github/workflows/kirkstone-stm32mp15.yml
My known working
dunfell CI (works):
https://github.com/meta-flutter/meta-flutter/blob/dunfell/.github/workflows/dunfell-stm32mp15.yml
Running the STM1 starter images of the same variant does work. So something about the image config.
Any ideas?
Joel
JoelBest answer
Aug 26, 2022 22:24 UTC
@Erwan SZYMANSKI​
It was the missing metadata.bin file. I had made my tests prior to adding the metadata.bin copy. The STMProg tool was failing looking for metadata.bin, so I had copied it for that; not realizing I just solved the problem.
Thanks for looking!
Erwan SZYMANSKI
Aug 26, 2022 09:43 UTC
Hello @Community member​ ,
Thank you for your contribution !
Regarding your logs, TF-A has troubles with the metadata check for FWU as explained in this article.
However, i see that you updated your .yml file between Dunfell and Kirkstone with taking this into consideration with copying arm-trusted-firmware/metadata.bin too.
I will investigate and try to reproduce from my side, I will let you informed.
Kind regards,
Erwan.
Joel
JoelAuthorBest answer
@Erwan SZYMANSKI​
Thanks for looking!
Erwan SZYMANSKI
Aug 28, 2022 17:55 UTC
Hi @Community member​ ,
Really glad to see that you were able to solve your issue !
Have a nice day !
Erwan.
