tzsolt
May 6, 2022 13:05 UTC
STM32MP157 LTDC RGB666
Is this processor capable to drive by parallel interface an RGB666 LCD display?
What could I set in the device tree?
1 reply
Jean-Marc S
Sep 6, 2022 13:54 UTC
Yes you can.
interface to LCD is called LTDC in our RM0436.
extract: "For LTDC outputs up to 24 bits (RGB888), if less than 8 bpp are used to output for example
RGB565 or RGB666 to interface on 16- or 18-bit displays, the RGB display data lines must
be connected to the MSB of the LTDC RGB data lines."
Also regarding DT you may find information here:
LTDC device tree configuration - stm32mpu
