WB55RG BLE Beacon Example via HCI only
Dear All,
I am search for an example BLE beacon code for the NUCLEO-WB55RG board which solely uses the HCI layer.
There is an example for the WBA board: https://github.com/STMicroelectronics/STM32CubeWBA/tree/main/Projects/NUCLEO-WBA55CG/Applications/BLE/BLE_BeaconHCI
Is there somewhere an analog example code for the NUCLEO-WB55RG board available?
Or does this code also work for the mentioned board?
Thanks in advise.
Andreas
