stm32wl55jc1
  • June 26, 2024
  • 3 replies
  • 1835 views
hello everyone
i try to make same ping pong dual core example but my project not working can you help me to found the problem
"there is not fault in build and i can run the project but it not working"
i did not understan where is the problem
STTwo-32
Hello @Humem_MHA
I suggest you compare your configuration to the configuration of this example and try to find the difference and why your code is not running.
Best Regards.
STTwo-32
Humem_MHAAuthor
I already configured it based on the example step by step, but I did not succeed in getting it to work, by the way when i make debug and try to run it Line by line some times it is working But this is not a solution
I guess there is problem with connection between cores or with clock , is it possible
STTwo-32
What I suggest you is to try to update your Firmware and IDE to the last version. It may be an issue related to the Cube Firmware or tool.
Best Regards.
STTwo-32
