STM32WB1MMC RF Layout
  • March 22, 2024
  • 3 replies
  • 1113 views
Hello
Is there any RF layout documentation for STM32WB1MMC? Minimum ground plane size, distance to PCB edges, copper clearance etc? I can't find anything.
STTwo-32
Hello @marc6h and welcome to the ST Community :smiling_face_with_smiling_eyes:.
I suggest you to follow this tutorial. Also, you can use the following application notes:
Best Regards.
STTwo-32
marc6hAuthor
Thanks, but none of this is relevant to the STM32WBxM modules. The whole point of these modules is to avoid all the RF and antenna design in those documents.
I simply expected some basic guidelines about module placement and ground plane; every other Bluetooth module has this.
STTwo-32
This Bluetooth module is based on the STM32WB1MMC . So I suggest you refer to the DS13258 and the Other MCU documents for more details.
Best Regards.
STTwo-32
