STM32 Bluetooth Classic MCU
Hi, I am wondering if you can get STM32 MCU with integrated Bluetooth Classic as the only examples I have found (Like WB55) are all bluetooth low energy?
STTwo-32
STTwo-32Best answer
Hello @Linkpad
ST is integrating the last BLE Technologie in the STM32WB series and specially in the STM32WBA series which include High data rate, long range, High output power and a Low-power messaging capability. I think that you can run almost all possible BLE applications using one of our MCUs. you can give as your project specification, and we may can guide you to a product that can do the job.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @Linkpad
Best Regards.
STTwo-32
Andrew Neil
Sorry to wake an old thread, but this has come up a few times recently:
@STTwo-32 wrote:
HI think that you can run almost all possible applications using one of our MCUs.
But not if your application needs to do Bluetooth Classic !
At the time of writing, with very few exceptions, that means pretty much anything with BT audio:
https://community.st.com/t5/stm32-mcus-wireless/stm32wba55g-dk1-not-compatible-with-all-mobiles/td-p/700344
https://community.st.com/t5/stm32-mcus-wireless/audio-on-stm32wb55cg/m-p/694244/highlight/true#M20065
Another example would be the Classic Bluetooth Serial Port Profile (SPP):
https://www.bluetooth.com/specifications/specs/serial-port-profile-1-1/
(There is no standard "serial port" profile for BLE - but plenty of proprietary implementations)
STTwo-32
I can confirm this. Thank you so much for this feedback @Andrew Neil . I've already mentioned that it implements BLE technologie.
Best Regards.
STTwo-32
