P-Nucleo-LRWAN2
  • April 23, 2024
  • 3 replies
  • 1408 views
Hello all,
I have purchased the p-nucleo-lrwan2 set that has a gateway and a end node. In the tools and software they have mentioned how to connect the gateway with LORIOT,TTN and Acitility. But I have a requirement such that gateway and end node-1 (i-nucleo-lrwan from the kit), end node-2(sx1276mb1mas shield with nucleo-l466rg) has to be connected to AWS and establish communication with each other.
 https://www.st.com/en/evaluation-tools/p-nucleo-lrwan2.html#overview
Looking forward for the support. Thanks in advance.
Best answer by STTwo-32
Hello @Krithika
First, the P-NUCLEO-LRWAN2 is not recommended for new design. So, I suggest you use another Product (Maybe the STM32WL as end Node and a gateway. Then, refer to the guidelines of AWS on how to connect to AWS drive (the AWS Forum should help you and also our X-Cube-AWS should be a good reference for how to connect).
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @Krithika
Best Regards.
STTwo-32
KrithikaAuthor
Hi STTwo-32
Thank you for response, I will go through it.
Thanks.
Andrew Neil
As @STTwo-32 said, the P-NUCLEO-LRWAN2 has been obsolete for  a while.
Certainly TTN has been significantly updated since then - so it's likely that the documentation is well out-of-date.
@Krithika wrote:
In the tools and software they have mentioned how to connect the gateway with LORIOT, TTN and Acitility. But I have a requirement such that gateway and end node-1 (i-nucleo-lrwan from the kit), end node-2(sx1276mb1mas shield with nucleo-l466rg) has to be connected to AWS
You should be able to find general documentation on how to get through LORIOT, TTN, Acitility, et al to AWS; eg,
https://www.thethingsindustries.com/docs/the-things-stack/host/aws/
This would not depend on what nodes or gateways you use.
