If I supply power only for SMPS, the microcontroller looks not booting. is it correct?
KKIM.6
Senior II
I'm designing a power line for the STM32WB55 microcontroller.
I'm checking the power system on the Nucleo-68 board but I found that the microcontroller cannot send a Bluetooth signal if I connect Vsmps only when booting the microcontroller.
I also found that it successfully work after removing VDD_MCU and VRF after finishing booting.
Is it correct?
It would mean I have to supply power to VDD also.
I also found that connecting VRF makes Bluetooth signal better.
Remy ISSALYS
Please have a look to chap 3.7 of the datasheet DS11929 for power supply management.
Best Regards
Remy ISSALYS
Best Regards
