How to change TCXO to Quartz Clock configuration SW LoRa_AT_Slave
I would like to try nucleo-WL55 in LoRa Node with Quatz and see temperature influence in RF signal.
So I have unsolder R2, and solder R39/R40. But now LoRaWAN_AT_Slave does not work anymore, even if I change TCXO to Quartz in .ioc file. I can see AT menu, but ATTONE does not work anymore.
- What change did we do to be able to use Quartz insted of TCXO?
- In LoRaWAN_AT_Slave MSI RC is configure. Why when I try to use HSE PRES /4 X12 /2 (48Mhz) I can't be able to see UART ? (AT menu)
