Disable BLE while Zigbee running
I would like to disable/re-enable BLE and keep the concurrent Zigbee stack in normal operation. Some other posts suggested to call hci_reset() to disable BLE and re-initialize it later when needed again.
After calling hci_reset() somehow Zigbee wont join the network anymore.
Are there shared components between the hci and Zigbee? Is what I am trying to achieve even possible with the tm32wb5x_BLE_Zigbee_FFD_dynamic_fw stack (I am using a P-NUCLEO-WB55)?
Thank you for any hint!
Best Regards,
Alexander
