Broadcast message using B-L072Z-LRWAN1 LoRa®/Sigfox™ Discovery kit.
I am using B-L072Z-LRWAN1 LoRa®/Sigfox™ Discovery kit. I want to implement broadcast communication using LoRa without gateway(not LoRaWAN). As I could see from the ping pong application sample provided as part of the I-CUBE-LRWAN SDK, that nowhere node address or security key are being used. So I presume it is very much possible to broadcast it to different nodes which are actively listening using just LoRa. Request your thoughts and help on this.
