CGong.1
Where is the "Configuring-STM32F746G-DISCO" page?
  • February 22, 2020
  • 8 replies
  • 2565 views
Where is the "Configuring-STM32F746G-DISCO" page? I used to see this topic in the help center, but now I can't find it. The previous URL was "https://touchgfx.zendesk.com/hc/en-us/articles/360019884752-Configuring-STM32F746G-DISCO". Now this link can't be opened, and I can't search for this topic, Where does this topic go? Was it deleted? Is there an alternative theme?
Romain DIELEMAN
this article has been removed because it was outdated. What is your ambition with it? If you just wish to run a project on your board, you can start from the application template in Designer when you create a new project. Everything will then be configured automatically and you can have a look at the generated CubeMX project. If you wish to learn how to port a board yourself the article has a lot of outdated content since it was meant for an older version of CubeMX.
\Romain
CGong.1
CGong.1Author
Hello Romain, Thanks for your reply! For some reason, I had to use an older version of STM32CubeMX, which is earlier than 5.4.0. Previously, I referred to the "Configuring-STM32F746G-DISCO" page and established the STM746G-DISCO project, and modified this project according to the instructions on this page to make it work normally. But now I can't find this page, it's very bad, I forgot some steps in this page. May I ask if you have a backup of this file, can you send me a copy, thank you. Chen �?��?自 Windows 10 版邮件<>应用
Romain DIELEMAN
Hi, ok then I will try to find a backup for it and link it here
Martin KJELDSEN
Principal III
February 25, 2020
CGong.1
CGong.1Author
Yes, this is the document I need. Thank you very much. That's great!
