TouchGFX library for Visual Studio 2022 missing (Platform toolset library v143)
jimmii
Senior II
Hi
I couldn't find a platform toolset library (v143) for visual studio 2022.
Do you have any plan on whether this will be provided?
Or maybe you already have them and could post them here?
/jimmii
7 REPLIES 7
Osman SOYKURT
Hello jimmii,
I don't really think your question is related to TouchGFX, is it ? I suggest you to add more tags to your post to make it more visible, maybe someone will have an answer for you.
/Osman
Osman SOYKURT
Hi @Osman SOYKURT​
Well it is related to TouchGFX, since you provide all the libtouchgfx libraries for the older Visual Studio installations. (See screenshot). As you can see, a library for v143 (Visual Studion 2022) is missing.
I talked to colleagues and v143 isn't planned yet. Have you tried to use libtouchgfx_v142 with your Visual Studio 2022 ? If it's not working I can report that to the team which is assigned to this work.
/Osman
Osman SOYKURT
Thanks. Yes that is working, but in order to get the v142 toolset library you have to install Visual Studio 2019.
So it's not a show-stopper but it would be great not having to install VS2019.
Do you have a time estimate for the v143 release?
Hello jimmii,
It's not planned yet but I'll let you know as soon as I have more info about it ;)
/Osman
Osman SOYKURT
Osman SOYKURT
Hello jimmii,
Can you try this please ?
In your application folder, find the msvs folder C:\TouchGFXProjects\YOUR_APPILCATION\Middlewares\ST\touchgfx\lib\win\msvs
Copy paste and rename theses files :
libtouchgfx_v142.lib(Copy) -->libtouchgfx_v143.lib
libtouchgfx_v142_debug.lib(Copy) -->libtouchgfx_v143_debug.lib
That should resolve your problem for now, we have planned to add this 143 library to our next TouchGFX Designer 4.19.0 version ;)
/Osman
Osman SOYKURT
I met the same problem too,
then I rename that two files....from v142 to v143,
This problem is resolved now,
Thanks..
oh​! my touchgfx version is 4.18.0......
maybe after upgrade TouchGFX Designer to 4.19.0 or higer version will solve this problem
