PFlor.2
Senior II
August 12, 2024
TouchGFX Designer v4.23.2 not generating IDE project files
  • August 12, 2024
  • 980 views
The last custom board project I did, the ST contact told me to start with TouchGFX designer (4.20.0) and generate the project from there.  Then I was able to import the existing project into STM32CubeIDE.  However the new version 4.23.2 does not seem to generate the .cproject and .project files in order to import the existing project into STM32CubeIDE.  Is there something I'm missing?
    Best answer by PFlor.2
    I found them under a STM32CubeIDE subdirectory
    PFlor.2
    PFlor.2AuthorBest answer
    Senior II
    August 12, 2024
    Hello @PFlor.2,
    Good to hear you have found the project. Could you please select your comment as 'Accepted Solution'?
    Best regards,
    Mohammad MORADIST Software Developer | TouchGFX
