MPast.1
May 8, 2024
TouchGFX Designer doesn't list all Win11 fonts
  • May 8, 2024
  • 1839 views
I don't understand why TouchGFX Designer can't show some windows fonts.
I download from internet the font called "GoogleSans-Medium.ttf" and I installed on Win11 correctly.
OpenOffice and others PC softwares allow to me to use it without any problem.
I try to reload TouchGfxDesigner a few times, I reload also Win11 but nothing happens: This font is not avaliable.
How can I use it in TouchGfxDesigner?
    Best answer by MPast.1
    HI,
    it works, but its necessary to close and re-open TouchGFX Designer.
    thanks a lot.
    GaetanGodart
    Hello @MPast.1 ,
    To use a font in TouchGFX Designer, importing it to Windows is not necessary.
    Instead you have to import it to your TouchGFX project by placing the file (.ttf) in your "myProjectName/assets/fonts" folder.
    After that, the font will be usable in Designer and in code.
    If this solves your issue, I invite you to select this comment as "best answer".
    Gaetan GodartSoftware engineer at ST (TouchGFX)
    MPast.1
    MPast.1AuthorBest answer
    May 11, 2024
    HI,
    thanks a lot.
