msalamon_pl
TouchGFX 4.16.1 doesn't generate images directory
  • March 7, 2021
  • 8 replies
  • 2014 views
I'm trying to run an example for X-NUCLE-GFX01M1 shield and I'm facing weird issues.
TouchGFX generator doesn't generate images data.
generated/gui_generated/src/screen1_screen/Screen1ViewBase.cpp:6:10: fatal error: BitmapDatabase.hpp: No such file or directory
     #include "BitmapDatabase.hpp"
I forced once but I can't make it again. What is wrong?
Romain DIELEMAN
You started a project from TouchGFX Designer with the application template for the STM32G0 nucleo board and with a UI template (or with an example in the Online Application tab) ? Or did you start your project from scratch ?
/Romain
msalamon_pl
I've started from TouchGFX Generator's online example for G0. It works now for me, but I made a step back to 4.16.0.
Romain DIELEMAN
Which online example did you use ? I was not able to replicate your issue.
/Romain
msalamon_pl
Hi! I hit the same issue with 4.16.0. I'm taking this example I noted that the first project with a fresh install and fresh workspace generates images ok. When I'm trying to make a second or further same project - images are not generated by the Designer.
Please try to make a few same projects from an online template in one workspace.
