ADębs.1
February 26, 2021
STM32F746G-DISCO, STM32CubeIDE 1.6.0 , TouchGFXDesigner 4.16.1
  • February 26, 2021
  • 5 replies
  • 1455 views
Hi
After compiling, I get an error: BitmapDatabase.hpp in the TouchGFXConfiguration.cpp file.
I checked three times. It repeats itself.
Andrzej
Best answer by ADębs.1
I did: https://www.youtube.com/watch?v=9QDWti5RzBU
There is the same mistake.
Andrzej
Romain DIELEMAN
How did you start your project ? Did you use the application template for the STM32F746 disco board available in TouchGFX Designer ? Did you create your own UI or did you use a UI template ?
What tollchain/IDE are you using ?
Could you share a screenshot of your issue ?
/Romain
ADębs.1
ADębs.1Author
March 1, 2021
I did it according to:
https://www.youtube.com/watch?v=12KXreXaLp0&t=3s
If this is the cause of the error, how to change?
Andrzej
