FMarr.2
STM32CubeMx LTDC version 5.6.7 produce code with 1 Layer, version 6.0 produce code for 2 layers even if set 1. Is this a bug?
  • November 27, 2020
  • 669 views
Open STM32H7BWorkshop2020 STM32H7B3I-DK.ioc first do not migrate, and generate code. Then migrate and generate code. Then check content of static void MX_LTDC_Init(void)
Khouloud ZEMMELI
Hello @Community member​ ,
Normally this issue has been fixed with the 6.1.0 CubeMX version, can you please check with it ?
Thanks, Khouloud
FMarr.2
FMarr.2Author
Hi, thanks for reply.
I am currently using 6.1.1 but i did not check if fixed. Just modified the produced code removing manually the second layer.
