Is there anything more font of Arabic text to show beside arabictype? How can i check the font is fine with TouchGFX?
Dd.21
I got trouble with Arabic text. And i get this information.
 But, how can i check the font is fine with TouchGFX?
Romain DIELEMAN
As explained in this article in the online documentation you can add the font of your choice in the asset/font folder of your project. I would recommend using a TrueType format (ttf) as the otf and bdf formats are supported by TouchGFX but not by TouchGFX Designer at the moment.
TouchGFX cannot compensate for rules that are embedded in a font so you have to make sure your font trully supports arabic (NotoNask Arabic is usually good for my projects)
/Romain
Thanks, Romain.
I will try this one.
