shark
How to draw a rectangle with round corner
  • June 8, 2020
  • 9 replies
  • 1595 views
How to draw a rectangle with round corner.
Alexandre RENOUX
Visitor II
June 9, 2020
You can do that by using an image editor (paint.net, photoshop, gimp) -> create a rectangle with round corners -> save the image as png (so that alpha is included) -> import this image in your touchGFX project and use the Image widget to add it to your screen.
/Alexandre
shark
sharkAuthor
Sorry, I need it at run time by coding.
Alexandre RENOUX
Visitor II
June 9, 2020
You can display the rectangle at run time whenever you want in the app. Just do rectangleImage.setVisible(true) when needed.
What do you want to do ?
/Alexandre
shark
sharkAuthor
Sorry, I need to draw rectangle with 4 round corner, with different size specified at run time.
Alexandre RENOUX
Visitor II
June 9, 2020
This is high level graphics programming and we don't have an example for it right now.
We will consider creating one.
/Alexandre
shark
sharkAuthor
Yes, hope you can release an example soon.
I have a lot of needs of different size, that require a rectangle as a background image. And png file is too expensive in code space.
I checked existing widget and example, but failed.
Alexandre RENOUX
Visitor II
June 9, 2020
If it's a background image, why do you need round corners ? I'm still lost on what you are trying to do exactly as a project.
/Alexandre
Tuoman
Senior II
June 9, 2020
Should not be too difficult to program it yourself.
I'm glad that TouchGFX is not full of bloatware to keep it light.
If you do this feature, please add it to open repository:
https://github.com/touchgfx/touchgfx-open-repository/tree/master/widgets
Martin KJELDSEN
Principal III
June 10, 2020
You could simply use a box, and then have corners with alpha in some sizes to create the rounded corners. Depending on what you're doing you may experience performance issues since we cannot use ChromART to draw the kind of shape you're after.
/Martin
