How to communicate an MCU to the STM32F746 DISCO using UART
  • February 24, 2024
  • 1140 views
Hi, I want to conect an external MCU to the STM32F746 DISCO using UART but I dont know how to use another UART other than the one used for communication with the PC.
Best answer by STTwo-32
Hello @ferdlf
As said @Andrew Neil, all UARTs work almost the same. I suggest you to take a look at this example to understand how it should be configured.
Best Regards.
STTwo-32
Andrew Neil
It's used just the same as the one for communication with the PC.
You allocate available IO pins, and then connect those pins to the other MCU.
STTwo-32
STTwo-32Best answer
Hello @ferdlf
Best Regards.
STTwo-32
